I getting warning message in AX 2009 server Event log ,where two AOS are installed (first is 2009 SP1 Hotfix Rollup 6 (RU6) and 2nd is 2009 SP1 Hotfix Rollup 6 (RU8)) when connecting with client of kernel version 5.0.1500.3761.
Massage : "Object Server 01: Internal aocp revision mismatch. Axapta client from XXXX-PC (0.0.0.0) tried to attach with 5.0.1500.3761 revision of kernel ".
How to install two AX 2009 Clients with different Kernel versions on same terminal machine ?
BR
Kathrin
