Can I install NAV2013 on windows 8 plateform? If yes then what is the procedure?
yes, you can
Did you try to install Demo option?
Yes you can install and it requires windows 8 64 bit
Following link will help you
http://msdn.microsoft.com/en-us/library/dd301330(v=nav.70).aspx
Dynamics NAV 2013 compatible with Windows 8.
Here is the system requirement for the setup
http://msdn.microsoft.com/en-us/library/dd301054(NAV.70).aspx
If you have queries regarding NAV implementation contact us through info@karyatech.com
Hi Naveen,
Did you get an answer to your question? Did it help you? The members and moderators here on DUG use our spare time and help you for free, all we ask in return is that you spent a few seconds to let us know if we helped you solve your problem.
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you, so that we can see that your problem is now “resolved”. Otherwise let us know how if there is something else you like to know.
Have a nice day! [:)]
