I have a Textbox.
Eg: Textbox1 := ‘Sagar’;
I want to insert the value of Textbox1 in the table named XYZ.
The sourceExpression of textbox is Textbox1.
Note: The value of Textbox1 is dynamic.
Textbox1 is a variable of type Code.
I have a Textbox.
What did you try till now?
What is the sourcetable of your form?
As mentioned the name of the table using form is XYZ
So Where is the problem you are facing ???
The field in table corresponding to textbox is blank.
I have added Textbox1 in SourceExpn.
How to insert value in Texbox1 in table XYZ.
Eg: Table - XYZ
Field - Name
SourceExpn of Textbox : Name
The value of textbox is dynamic. So i created a variable Textbox1.
I am doing OnPush : Textbox1 := ‘Sagar’;
Now i want this Sagar in Name field of Table XYZ.
I am bit clear about the requirement.
You can write code on Onvalidate trigger or create one button and write a code on that
Anyone please reply if there is another solution.
I got the solution as below:
I created a new table Country with fields as below:
ID | Name
1 | India
2 | USA
SourceExpn of Textbox is set as Name of Country:
recCountry.RESET;
recCountry.SETRANGE(recCountry.Name,‘India’);
IF recCountry.FINDFIRST THEN
Status:= recCountry.Name;
CurrForm.UPDATE;
NOTE: I need to change only the field India,USA … in SETRANGE
