How to increase Performance of EP site .......
Is there anyone who can tell me …how do we increase performance of an EP site when multiple users processing data from Dynamics Ax…
Is there any Functional setup or we can do some changes in our query…
Reply…
Here are some tips to improve the performance of your EP site.
1- Try to not use caching , this will literally overflow the memory of your server keeping useless stored values for long times.
2- Check the field list in the query’s or in the ‘select’ methods that call the database. Less fields to return also improve a lot your performance
3- Consider placing javascript validations if they are not already in use. Some .net components already validate in the client and server side if the process can be successfully completed, but double check your EP site, so if javascript is not implemented you may be wasting server resources to simple validations as empty fields and invalid fields.
4- Consider the use of recordset functions of dynamics. If you are using for example updateRecordset to update 10 records related to a main record, you may reduce the travel of data to the database from 10 to only 1.
5-Set a lower expire session timer to your users. This will kill the sessions no longer in use and may gain a little to overall performance.
Well just some tips, Good luck improving the performance!
