please help me urgently on what’s the procedure to increase the inventory count of a particular item. i have tried posting a purchase order but in vain…plz help.
have a postive adjustment
you can do the above thru Item Journal…entry type Positive Adjmt.
thnk u so much for ur help…i am done wid the process…thnz again…
Dear Rupal,
Please remember to click the “Verify Solution” on Amer’s post, if this solved your problem.
Thank you.
I hope for your sake and the clients that this is a test only. What are you trying to acheive?
Hi Rupal,
Why do you want to increase inventory?
Are you doing it on production (live ) server? If it is just on test database and for learning purpose, then it is OK, otherwise this should never be done…
