How to import multiple file from a folder?
Hello,
Currently we can import a file (acsii) into AX. But can we search all file in 1 folder to import the each file 1 by 1?
AsciiIO asciiIO;
asciiIO = new AsciiIO(filePath, ‘R’);
asciiIO.inFieldDelimiter("\n");
asciiIO.inRecordDelimiter("\n");
while (asciiIO.status() == IO_Status::Ok) {
line = conpeek(asciiIO.read(), 1);
Hi Kenl
This will help to build a list of files in a folder. Then you can load the file one by one.
container createListOfFiles(FilePath _path = path, FileNameType _pattern = pattern)
System.Array files;
int fileCount;
int i;
str nextFile;
new InteropPermission(InteropKind::ClrInterop).assert();
info(strfmt(‘Search in: %1 %2’, _path, _pattern));
listOfFiles = connull();
actIx = 0;
files = System.IO.Directory::GetFiles(_path, _pattern);
if (files)
fileCount = files.get_Length();
info(strFmt(‘Number of files in directory: %1’, fileCount));
for(i=0; i < fileCount; i++)
nextFile = files.GetValue(i);
listOfFiles += nextFile;
CodeAccessPermission::revertAssert();
info(strFmt(‘Files count: %1’, conlen(listOfFiles)));
return listOfFiles;
Best Regards
Fensmark
Thank you very much for the solution.
I use another method to get it.
[handle, filename] = WINAPI::findFirstFile(filepath + “\*.txt”);
while (fileName != “”)
try {
this.executeFile(fullFileName);
numFileImport++;
filename = WinAPI::findNextFile(handle);
Hi Kenl,
I’ve the same problem… I want to upload multiple files from one folder.
but I con’t understand the above coding shall you post full method & steps I will understand…
Thanks in advance
Regards
Rajab.
Hi Rajab,
To get inspiration have a look under SysHelpSetupWizard class → getLanguages method.
