How To Import General Journal Header using X++ Code And Lines Import From Excel
There are number of example over web, you can search them.
BTW, you can also use Import/Export framework and excel-addin
blogs.msdn.microsoft.com/…/
ax2012exceldataimport.blogspot.in/…/dynamics-ax-2012-ledger.html
Hi Kranthi…,
I am Ask Using X++ Code
You can execute it from X++, of course. What problem do you have with it.
Obviously designing, implementing, testing and maintain your own code for something that AX already contains (and Microsoft supports) would be a waste of time.
