how to import excel fileto VendTable and add more fields.....
Hello everyone
i need to import data from excel to Ax VendTable
for that i have added new fields namely IFSC, MICR & Bene_Bank_Acc in Vend Table.
now if VendorAccount in Excel Match with VendorAccount in Vend Table then above 3 fields data will import into Table for respective Vendor Account.
if not matches then throw error like Vendor Account not Exist.
i have attached the VendTable word Document & Import Excel sheet for reference.
please find it & reply soon.
thanks in advance!!!
waiting for early response…
Manali
Hi Manali,
below code may help you.
static void ReadExcelFile (Args _args)
SysExcelApplication excel;
SysExcelWorkbooks workbooks;
SysExcelWorkbook workbook;
SysExcelWorksheets worksheets;
SysExcelWorksheet worksheet;
SysExcelCells cells;
COMVariantType type;
int row;
vendaccount account;
vendtable vendtable;
str IFSC, MICR,Bene_Bank_Acc;
#define.filename(@‘file path’)
excel = SysExcelApplication::construct();
workbooks = excel.workbooks();
try
workbooks.open(#filename);
catch (Exception::Error)
throw error(“File cannot be opened”);
workbook = workbooks.item(1);
worksheets = workbook.worksheets();
worksheet = worksheets.itemFromNum(1);
cells = worksheet.cells();
type = cells.item(row+1, 1).value().variantType();
while (type != COMVariantType::VT_EMPTY)
row++;
account = cells.item(row, 1).value().bStr();
IFSC= cells.item(row, 2).value().bStr();
MICR = cells.item(row, 2).value().bStr();
Bene_Bank_Acc = cells.item(row, 2).value().bStr();
account = ventable::find(account);
if(!account)
throw error(" Vendor not present");
else
ttsbegin;
vendtable.selectforupdate(true);
vendtable.IFSC= IFSC;
vendtable.MICR = MICR;
vendtable.Bene_Bank_Acc = Bene_Bank_Acc;
vendtable.update;
ttscommit;
excel.quit();
Hi, below is a simple job to insert record using excel sheet
static void toInsertVendor(Args _args)
SysExcelApplication application;
int row=1;
vendAccount vendAccount;
IFSC _Ifsc;
MICR _micr;
Bene_Bank_Acc _Bene_Bank_Acc;
FileName filename;
Vendtable objVendtable; Table in which record is to be inserted
application = SysExcelApplication::construct();
workbooks = application.workbooks();
//specify the file path that you want to read
filename = “C:\New folder\VendRecords.xlsx”;
try
workbooks.open(filename);
throw error(“File cannot be opened.”);
do
row++;
vendAccount= cells.item(row, 1).value().bStr(); //I assumed that column 1 is for VendAccount
_Ifsc = cells.item(row, 2).value().bStr();
_micr = cells.item(row, 3).value().bStr();
_Bene_Bank_Acc = cells.item(row, 4).value().bStr();
select objVendtable
where objVendtable.VendAccount== vendAccount;
if(objVendtable.RecId != 0)
ttsBegin;
select forupdate objVendtable
objVendtable.IFSC= _Ifsc ;
objVendtable.MICR = _micr ;
objVendtable.Bene_Bank_Acc = _Bene_Bank_Acc ;
objVendtable.update();
ttsCommit;
else
warning(strfmt("%1 does not exist in Vendtable",objVendtable.VendAccount));
while (type != COMVariantType::VT_EMPTY);
application.quit();
hi saddaf &Jagannath Tripathy,
Thanks for the code,its running,but didnt get correct output…
want to show total rows in excel ,vender account matches how much and mismatch accounts…
i want this as an result then what to do,plz suggest solution…
Thanks.
Manali.
Hi Manali,
I have added few more code which may help u.
int row;
int i,j,k;
try
row++;
i = 0;
j= 0;
k = 0;
j++;
if(!account)
i++;
else
k++;
ttsbegin;
vendtable.update;
ttscommit;
info("%1 rows mismatch account",i);
info("%1 rows total rows",j);
info("%1 rows match account",k);
excel.quit();
