Running AX 2012 R3 with excel 2013 and doing custom development. (creating tables, forms, SSRS reports).
I’m using Data import export framework. I’ve the source file in excel format and I want to import all the data from this excel file to corresponding table in AX.
I’ve create a new custom entity and processing group for the AX table. But when I hit generate source file an error message shows after exporting table fields into an excel sheet. Also, browsed file name under the folder path.
"Method saveAS in COM object of class _Workbook returned error code 0x800A03EC() which means ‘tableName.xls’.
What is the best way to resolve this? OR any links that I can follow to find out more about this issue.
Thanks in advance!!
