Di Friends. How to import data from excel file without programming? thanks
Hi massoud, you can use Data Import/Export utility. Create Definition Group, then select which tables you want to include, and then export using CSV (Comma Separated Values) format, which can be opened using MS Excel. You will see the format, and just add needed records. This is a little bit complex then this, so I sugest reading about this in Developer’s Guide. Second solution is to have someone develop this for you [:)]
