How to Import CSV File for LedgerGeneralJournalService using C# code.
I need to import csv file for LedgerGeneralJournalService.
I need c# code to do this.
Thanks in advance.
With which part do you need our help? Calling the web service? Reading CSV files from C#? Something else?
Thanks for reply.
Using webservice i want to import CSV file and create Journals.
Here,I’m reading CSV file using c# code.
Yes, I know, but what’s them problem?
Please answer these two questions:
  1. Do you know how to call a web service?
  2. Do you know how to read CSV files from C#?
If you know both, then please explain your actual problem, because you haven’t done it so far.
yes.while reading csv file i’m facing problem.
What kind of problem? Could you explain what you need without interrogation, please?
