How to import bank statement in csv format in to Dynamics nav Table.
Is there any solution out for this?
You can use dataport & some code.
You can user dataport /XMLport on the basis of client you are using. As well as you need to set the format as per navision table structure as Bank statement comes in bank format.
Dataport/XML port
I have csv file but with bank format how can i import that in to navision
Some local versions have that functionality “on board”. What local version are you using?
I am using North america. Which local version has that?
Ouch, not familair with that version, so I cannot be of help to you.
