I haven’t had much opportunity to try out XMLPorts as dataports and am a bit stuck.
I have an already created Item Journal in NAV (Created from a Warehouse Physical Inventory Journal) and I want to update the Unit Cost on each line from a flat file (I do not want to change the Item Card details. These need to remain the same.)
The flat file consists of: “Item No.” “Unit Cost”. The Xmlport Format property is set to “Variable Text” and I have based this round the Integer table (With a filter of Number = 1).
I can write the code to find the Item Journal lines by item, Template Name and Batch Name and update them but I need to pass the Unit Cost into a variable on importing the file to do this, and I don’t know how you do this. The Source Types seem to only be Text, Table or Field.
This seems a fairly fundamental thing to do, so I am clearly overlooking something? [:D] How do you do this?
Many thanks in advance
PS Update - I can resolve the above using the EVALUATE function in my code, but am now stuck as to which table I should use. I was basing the Xmlport on the Integer table as I would with an old style dataport, but I get the error message “The Integer table is read only” when trying to import my test file. Any suggestions please?
