How to hide some menuitems under menus in content pane
I want to hide some menuitems under Menus when AX start or change company in AX 2009. For example I have two menuitems, menuitemA, menuitemB under menus. When It is compay A, I want to show only menuitemA. when it is companyB, I want to show only menuitemB. Does anyone know?
Thanks!!
Paicy
With the help of security keys, roles set by the system administrator.
hi ,
u can write the code in sysstartupcmd class to find the company and u can make visible true or false the menuitem
thanks,
sreekanth
Hi Screekanth,
Thanks for you reply, I don’t how to make menuitem under Menus invisible. there is a property called “IsDisplayedInContentArea”, But when I try to set it, error occur, My code is as below
treeNode treeNode;
xInfo xInfo = new xInfo();
treeNode = xInfo.rootNode();
treeNode = treeNode::findNode(“Menus”).AOTfindChild(“HamicyOS”).AOTfindChild(“PatientDetails”);
treeNode.AOTsetProperty(“IsDisplayedInContentArea”, noyes::Yes);
Thanks a lot.
Paicy
Hi Abhinay,
You are right, Menuitems can not be hidden without the help of Secuirty key.
Thanks a lot.
Paicy
