we came across this situation where the user (not admin user) can have rights to create user, setup user groups and permissions. But we want to restrict certain users (who is not a admin) to create new users, user groups and assign permissions except for certain security keys like Sysdevelopment … Can this be done in ax 2009 ? Please advice.
If you have a look to SysUserInfo table (contains AX users), the security key property is Admin table.
You should check your user’s group and go to Administration/user groups, select your group then access permissions button then permission access Tab, in the treeview go to Administration node, expand then table node expand then user info node.
Normally, you should see that your user has creation permission on user info table, you just have to change permissions at this place. Be careful, your modification are applied to groups not specifically to your user
For more info, google on dynamics AX security keys management
