When I’m trying to run the debugger from NAV 2013 then I’m getting this error when starting the Windows client from C/SIDE:
The client version does not match the server version. You can only connect to a server with a matching version.
Client version: 6.0.33910.0
Server version: 7.0.33781.0
The error is because I have both NAV 2009 R2 and NAV 2013 installed and the debugger is trying to start NAV 2009. I’m having the same error if I’m trying to run a page or similar from NAV 2013.
Does anyone know how to make sure that NAV 2013 starts the correct NAV 2013 service?
