Hi Martin,
Now i am getting this error(Event Viewer). Do u have any sample codes or template codes to handle the AxForm(AxGroup) and AXGridView (Header-Line) in a user control? i am getting other errors also in some controls having both AxForm and AxGridView. I Got some idea from the link.
Error:
Dynamics Object Adapter Call failed.
RegisterRequiresControlState can only be called before and during PreRender.
System.InvalidOperationException
at System.Web.UI.Page.RegisterRequiresControlState(Control control)
at System.Web.UI.Control.AddedControl(Control control, Int32 index)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxBaseGridView.AddedControl(Control control, Int32 index)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxBaseGridView.CreateChildControls(IEnumerable dataSource, Boolean dataBinding)
at System.Web.UI.WebControls.CompositeDataBoundControl.PerformDataBinding(IEnumerable data)
at System.Web.UI.WebControls.GridView.PerformDataBinding(IEnumerable data)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxBaseGridView.PerformDataBinding(IEnumerable data)
at System.Web.UI.WebControls.DataBoundControl.OnDataSourceViewSelectCallback(IEnumerable data)
at System.Web.UI.WebControls.DataBoundControl.PerformSelect()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxBaseGridView.PerformSelect()
at System.Web.UI.WebControls.BaseDataBoundControl.EnsureDataBound()
at System.ComponentModel.ListChangedEventHandler.Invoke(Object sender, ListChangedEventArgs e)
at Microsoft.Dynamics.AX.ManagedInterop.ClrBridgeImpl.ExecuteHandler(ClrBridgeImpl* , ObjectWrapper* pObjectWrapperHandler, ObjectWrapper* pObjectWrapperSender, ObjectWrapper* pObjectWrapperEventArgs)
at AxEventDelegate.kcInvoke(AxEventDelegate* , interpret* ip)
at cqlClass.callEx(cqlClass* , Char* , interpret* )
at AxCore.AxRuntime.Call(AxRuntime* , IAxObject* axObject, String methodName, Type returnType, Object& result, Object[] paramList)
at Microsoft.Dynamics.AX.ManagedInterop.Object.CallWithReturnType(String methodName, Type returnType, Object[] paramList)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsObjectAdapter.Call(String methodName, Object param1)
