hi,
I am jst working in report,how can i group the fields in the report. i mean if i work on item ledger entry list report and i want item no comes 1st and related data comes under that item no. and each no print only one time. can anyone help me?
hi,
This “grouping” is done by the item number (group by)
The item itself needs to go into the group header for that group.
Thanks Sir,
But sir i have to group three field.
Ex - i have 5 fields
Item no Entry type posting date location code Amount
1100
sale
01/12/2015 BLUE -3500
purchase
02/12/2015 green 250
1200
sale
01/12/2015 BLUE 250
It should be look like this so what to do
now my report look like below
Item No. Entry Type Posting date Location Cod Cost Amount (A
1001
Sale 01/27/11 BLUE -3,505.94
Sale 01/27/11 YELLOW -3,505.94
-7,011.88
1100
Positive Adj 06/01/10 934.20
Consumptio 09/09/11 -648.36
Consumptio 09/10/11 -3,501.12
Consumptio 09/11/11 2,074.74
Sale 01/27/11 BLUE 2500
Thanks Sir,
1100
sale
purchase
1200
sale
01/12/2015 BLUE 250
1001
-7,011.88
1100
You can create nested groups.
You will find an example in Report 206 Sales Invoice, which already uses exactly these nested groups you are asking for.
So your first group is grouping by “Item No.” and the second group is grouping by “Item No.” and “Entry Type”.
Third group could group by “Item No.”, “Entry Type” and “Source No.” if you want.
for the nested group i have to write code or what? because in report 206 lots of table used, but i am using only one field,and for grouping we required group total fields and Item table view properties for key selection because which field i am going to make grouped that must be selected in the item table view properties,but how can i select more field in that properties.If it will done by code then pls guide me
You need to create key on item ledger entry table and use it in the report
Thanks sir,
But i have to group several fields not only one field,so how can i do
you need to create a key with all fields…
