Can any one help mw whats wrong with this code?
I want to get list of fields in a infolog which have Visible property as ‘No’.
static void Job5(Args _args)
TreeNode vendFldsRoot = treeNode::findNode(@"\Data Dictionary\Tables\VendTable\Fields");
TreeNodeIterator vendFldsIterator;
TreeNode vendFlds;
NoYes visibleProp;
vendFldsIterator = vendFldsRoot.AOTiterator();
vendFlds = vendFldsIterator.next();
while(vendFlds)
visibleProp = vendFlds.AOTgetProperty(‘Visible’);
if(!vendFlds.AOTgetProperty(‘Visible’))
info(strfmt(“field %1”, vendFlds.treeNodeName()));
Harish
2
Hi Swapna,
You are close. Try this -
while(vendFlds)
if (vendFlds.AOTgetProperty(#PropertyVisible) == ‘No’)
Harish
3
Full code below -
static void Test_Iterator(Args _args)
TreeNode vendFldsRoot = treeNode::findNode(@“Data DictionaryTablesVendTransFields”);
TreeNode vendFlds;
#Properties
while(vendFlds)
info(strfmt(“field %1 **, Visible Property %2”, vendFlds.treeNodeName(), vendFlds.AOTgetProperty(#PropertyVisible)));
That was silly mistake. Thank you
