How to get the Main TableForm From Another Form
I Am create 2 tables Table1,Table2
and also created forms for the table1,table2 as Table1form, Table2form
( Added these two forms into Menu item Display tab)
i created areation between these 2 tables by using EDT level normal relation
and i gave the Table1form as the Formref to Table2
now i opened Table2 From Right click on the related field column → Choose GO TO Maintable form
but i didn’t get the Table1 Form . it’s opening same form why ?
how to get the table1form ?
(I Am also tried with table level normal relation but i didn’t get output. y?
After Adding the form1 into an MenuItem i am getting an error message while click on GoToMaintable8203.Error.jpg
Y The error messge coming…?
Any one having the idea…
HI Roshan,
You need to mention the FormRef property on the table1…
You can get look up in many ways - by using an EDT with relation (or) form ref property (or) by putting some code using the SysTableLookup class
this link may help you http://www.axaptapedia.com/Lookups
I mentioned in the table2 FormRef → Table1Form
i want table1form form the table2form
how can i get it?
Hi Roshan
When you open the Table2Form and GotoMain table – Table1Form
then need to mention the ‘table2’ — FormRef property as menuitem of ‘Table2Form’.
Thanks for u r reply…now i got the Solution…
but some confusion
Hi Roshan
then need to mention the ‘table2’ — FormRef property as menuitem of ‘Table1Form’.
To Naresh Kumar Kolli,
Thank’s for u r reply…
To Naresh kumar,
I mentioned in the Table2 → Form ref–> choosen table1form
Now aging i have to choosen the Table1 → Formref → Table1Form
Now i got the solution…
is it nessary to mention Table1FormRef → Table1Form
Let’s take a example
In SalesTable There is no FormRef
In the SalesOrder Form when i choose the GoTo Main Table From customer Account Field
It opens CustDetails Form where the relation is established ?
Hi Roshan,
That is because of relation at ‘extended datatype’ of the ‘CustAccount’ .
Just check with this,i think u have created the table and the form… add the custAccount edt in one of the table and also in the form… Open the form and check the custAccount it will go to the custTable form…
To Naresh Kolli,
In the same way i am created a EDT (Relation) and assign the same EDT to 2 fieds
one field is in table1 & another one is in table2
It shows me a drop down box but when i choose the Go To main table ( there is no table level relatio here)
it won’t take me to the table2form to table1form until i filled the properites as
Table2 FormRef → as Table1form
Table1 FormRef → as Table1form
Why it is happening…?
NO need to give the relation between the two tables. Create an EDT → with relation EDT == Table1.column
use the EDT in the table2 add the field to table2from now when you do go to main table for that field in the table2 form then actually it will take you to the table1From (Modify the name of form table1from to table1(which is the the table name) and try)…
Thanks kranti…
i changed the form Name & I got the solution…
Create a EDT (Relation) and assign the same EDT to 2 fieds in the two tables
It shows you a drop down box but and GoToMainTable,but not require any table level table level relation
Until and unless you specify the FormRef property for the it wont go…
