how to get the lookup on parameter ax_companyname?
I want to get the look up on AX_Companyname. this lookup has to show the list of companies.please send me how to do it.
If you need help, you’ll have to be a bit more specific. where(place) and why…
Thanks for your reply Krishna. I need the lookup on parameter dialog box(in ax) and sharepoint . becuase whenever report is using customized parameter it is only showing data for default company, not showing for other company. but if i use standard parameter it showing for all companies irrespective of default company but i need to implement look up on this parameter to see all companies
sorry, i’m not aware of this.
I will try,if you send your Customized code.
