I want to get the diffference between two dates
for ex 1st date 31/01/2011
2nd date is today
result should be 9 days
How to get this in AX ?
Thanks in Advance
2nd date is today
Thanks in Advance
today() - mkdate(31,01,2011) ;
Thanks for ur reply…
if it s today - transdate?
It will work. Just subtract both the dates as suggested by Kranthi.
In mkdate(day, month, year). Here how will i pass transdate?
Transdate d;
d= 31\12\2010;
today() - d;
This is not my requirement. I want to take the transdate from custtrans table.
today() - CustTrans.transdate;
Could you elaborate more ?
Hi monika this s not correct…
What is your problem in that?
If i write like this
Date invoicedate;
invoicedate = today() - custTrans.TransDate;
error
operand ttypes are not compatible with the operator
try this…
static void DateDiff(Args _args)
TransDate d1,d2;
int daysdiff;
d1 = 31\12\2010;
d2 = today();
daysDiff = d2 - d1;
info(strfmt("%1",daysDiff));
Naresh
It will return an integer not the date. Here you are trying to find out the difference between two dates - the interval - which will return an integer and not the date…
Hai Praveen,
date2num(systemdateget()) - date2num(urtable.date);
Hope it will help
Regards
Shon[Y]
Difference will return an integer not a date. Thats why u r getting an error.
Thanks to all…
Hi Praveen,
You just change the ‘invoicedate’ datatype as–> int
date2num(date1) - date2num(date2)
U will result in number
Try in this format Reply me after trying this.
How get difference amount various dates ex SO date(SalesTable -table) - invoice date(CustInvoiceTrans- table)
and i require it in sales line table so i am trying to write a method here
Thanks in advance
Hi …
i am new of dynamics ax …
i have one doubt;;;;
if … from date and to date datas having from tables…
example’;
fromdate: 10.03.2016
tadate: 12.03.2016
command button (calculate)
result: 2
i need coding about this concept… in clicked method
