How to get server(AOS) timezone through x++ code in AX 2012?
Ambanna Yatnal
Ambanna Yatnal
Ambanna,
There is a class you can use, called DateTimeUtil, that has a method getSystemDateTime which returns the server’s date and time in UTC format.
//declare variable
utcdatetime timeVar;
timevar = DateTimeUtil::getSystemDateTime();
~S
Hi Silvano,
Thanks for the reply. How do I get which timezone is used in that datetime? say for example GMT+5.5
-Ambanna Yatnal
Hi Ambanna Yatnal,
try this in Job
print xGlobal::machineTzDisplayName();
pause;
