I need to get path of various menu items that are stored in a table from module
for example ,
menuitem: customer assets
module: customers
then the returned path needs to be:
customer\customerDetails\customer assets.
Thank u guys in advance
for example ,
module: customers
This could actually lookup all the instances where this particular menu item is called from.
You need to specify the type of menu item it is, like display or output menuitem.
static void JobMenuItemPath(Args _args)
#TreeNodeSysNodeType
#Properties
#AOT
TreeNode menuItemNode = TreeNode::findNode(@"\MenuItems\Display\CustTableListPage");
TreeNode menuNode;
xRefPaths xRefPaths;
xRefReferences xRefReferences;
TreeNode parentNode;
Str path;
if(menuItemNode)
xRefPaths = xRefPaths::find(menuItemNode.treeNodePath());
while select xRefReferences
where xRefReferences.referencePathRecId == xRefPaths.RecId
&& xRefReferences.Reference == XRefReference::Read
path = SysLabel::labelId2String(menuItemNode.AOTgetProperty(#PropertyLabel));
menuNode = TreeNode::findNode(xRefPaths::findRecId(xRefReferences.xRefPathRecId).Path);
if(menuNode && SysTreeNode::path2ApplObjectType(menuNode.treeNodePath()) == UtilElementType::Menu)
parentNode = menuNode.AOTparent();
while(parentNode && parentNode.treeNodePath() != #MenusPath)
path = SysLabel::labelId2String(parentNode.AOTgetProperty(#PropertyLabel)) + " > " + path;
parentNode = parentNode.AOTparent();
info(path);
