How to get entry points under the roles using x++
Please help me.
Thanks in Advance !!!
Please help me.
SecurityEntryPointLink , SecurityTaskEntryPoint , SecurableObject are tables that you need to look at.
But to get the data from those tables for a given role you need to use other security related tables. Have a look at \Classes\SysSecObjectsInRole\GenerateData
Hi kranthi,
Below code are working fine for me getting all entry points under the Role…but here i need to get the who are the access “finUser” Role related modules and related entrypoints.
static void SecurityRoleEntryPoints(Args _args)
SecurityTaskEntryPoint taskEntryPoint;
SecurityRole role;
SecurityRoleTaskGrant taskGrant;
SecuritySubTask subTask;
SecurityTask privilege;
SecurityTask securityTask;
SecurableObject securableObject;
RecId roleRecId;
#AOT
str userlicense, maintainlicense, privName;
TreeNode treeMenuItem;
TreeNode treeMenu;
while select RecId, Name from role where role.AotName == ‘FinUser’
roleRecId = role.RecId;
while select securityTask, SecurityRole from taskGrant
join RecId, Type, AOTName from securitytask where securityTask.RecId == taskGrant.SecurityTask
&& taskGrant.SecurityRole == roleRecId && securitytask.Type == SecurityTaskType::Duty
join securityTask, SecuritySubTask from subTask where subTask.SecurityTask == securityTask.RecId
join securityTask, EntryPoint from taskEntryPoint where taskEntryPoint.SecurityTask == subtask.SecuritySubTask
select RecId, Type, Name from securableObject
where securableObject.RecId == taskEntryPoint.EntryPoint && (securableObject.Type == SecurableType::MenuItemDisplay
|| securableObject.Type == SecurableType::MenuItemAction || securableObject.Type == SecurableType::MenuItemOutput);
if( securableObject)
select RecId, Type, AOTName from privilege where privilege.RecId == subTask.SecuritySubTask && SecurityTaskType::Privilege == privilege.Type;
privName = privilege.AotName;
info(strFmt(“Role: %1 Duty: %2 Priv: %3 Menu item : %4”, role.Name,securitytask.AotName,privName,securableObject.Name));
//sometimes a role has a privielge direclty assigned instead of a duty. So this code is for those privileges. In this case duty will not exist.
while select SecurityTask, SecurityRole from taskGrant
&& taskGrant.SecurityRole == roleRecId && securitytask.Type == SecurityTaskType::Privilege
join securityTask, EntryPoint from taskEntryPoint where taskEntryPoint.SecurityTask == securitytask.RecId
info(strFmt(“Role: %1 Duty: Priv: %2 Menu item : %3”, role.Name,securitytask.AotName,securableObject.Name));
Do you mean getting all the users related to that roles? If so, you can get the data from SecurityUserRole table.
No kranthi…The user should access the following expanding entry points (like vendors, invoices, purchase orders, vendors in Reports area) only as shown in the below screen shot and other entry points should not.
That is different issue. Please create a new post.
