How to get debit balance and credit from sql server in dynamic nav 2009
Hi guys i have dynamic nav 2009 and sql server 2005
I have this query show data from sales line and sales header
SELECT ROW_NUMBER() OVER (ORDER BY dbo.[Jeddah-Live$Sales Header].No_) AS [م], dbo.[Jeddah-Live$Sales Line].[Document No_] AS ‘رقم الطلب’,
dbo.[Jeddah-Live$Sales Header].[Bill-to Name] AS ‘العميل’, dbo.[Jeddah-Live$Sales Line].Area AS ‘نوع الصبه’, dbo.[Jeddah-Live$Sales Line].Description AS ‘البيان’,
dbo.[Jeddah-Live$Sales Header].[Pump No_] AS ‘المضخه’,dbo.[Jeddah-Live$Sales Line].[Outstanding Quantity]
FROM dbo.[Jeddah-Live$Sales Header] INNER JOIN
dbo.[Jeddah-Live$Sales Line] ON dbo.[Jeddah-Live$Sales Header].No_ = dbo.[Jeddah-Live$Sales Line].[Document No_] AND
dbo.[Jeddah-Live$Sales Header].[Sell-to Customer No_] = dbo.[Jeddah-Live$Sales Line].[Sell-to Customer No_]
WHERE DATE DIFF(d,dbo.[Jeddah-Live$Sales Line].[Shipment Date],GETDATE()) = 0
The query above success work and show data based on date today
My question :I need to add debit balance and credit balance to every customer
from starting period until today
How i do that
the report i need as following
but i need query because i need to do something customization but outside dynamic
Note from dynamic nav i can do no problem
but only i need to do it from sql
this report what i need to do from sql
First your query above is wrong. You need to relate the lines based on the full primary key of the header. Don’t assume a document number is unique. It is possible to have the same document number as post an order or credit memo, as an example.
On your questions, I’d suggest looking at how NAV produced those numbers. Look to reports or pages where that information would normally be viewed in NAV. Then use the logic of that function to design your SQL queries. It will also give you something to test your queries against. For example, run a “Customer Trial Balance” or “Customer AR Aging”. Do your SQL queries yield the same results.
Thank you for reply
Can you help me in write view collect IN SQL SERVER 2005 TO GET
Sum of debit balance to every customer from (details customer ledger entry table)
AND
Sum of credit balance to every customer from (details customer ledger entry table)
AND
Customer No from (customer table)
AND
Customer Name from (customer table)
Relation between customer table and details customer ledger entry table
