how to get data of Table fields in customized table?
I want to view Fields in a lookup field
Table ID Table Name Table Fields
23 Vendor No. ( from look up fields)
23 Vendor -------------------- in lookup all fields of vendor will came and i can select any one of these field
please tell me any solution how i take table fields in lookup
can you be more clear?
Sorry unable to attch image
Like the same when i use lookup for Table fields, Then I got all the vendor table fields (at the time of lookup)
Like “No.”, name , Address,address2,City,phone,Contact,Country,Etc all fields
You need look up for Name,address etc fields?
yes and if i entered table in table id is customer then the fields in customer table will show in lookup
Did you check field table? it wont give you look up but will give you all field details…
Nice Thanks, But User Dont know that what to select in the table
can we do some modification in field by entering new field or variable in form level and then send the data to my table.
When user do look up in table 23 and field No. he needs to see all vendor No’s?
Hi Raghubir,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
