Could you advice me how to control writting, modifying, deleting data in Navision tables , directly from SQL ?
I mean , I want to know if some users modify data in G/L Entry table directly from SQL. The IT auditors need to verify this and to be sure that the product is safe.
(navision version is 5.0SP3, with SQL database, Windows Authentication)
If you use “Standard” security model (recommended), then your users have no rights to change data directly in SQL. Unless you have explicitly granted those rights.
