I can know who has updated a master record…but dont know what field is updated… can we know that ?
You could use the “Change Log” for this (I think it’s been available since Version 3.6). In the Setup, you can define the Tables you want to track. You can choose the fields you want to track (all or some), and the user actions (Delet, Insert and Modify).
Thanks…but can u explain a little bit more… where excatly i can find that form… and how to set it…
Dear Masqazi If you are in Navision 4.0 then go to Administration Module & then to Application setup-> General you will find Change Log Setup Click on the Activate Field & then move to setup tab where you can select the table & it’s all or some fields. Ashish
