How to find unposted transactions- close a period
Hi guys,
I try to close a period but got below error. I check all the transaction and wouldn’t find any unposted transactions. Is there any clever way to find opentransactions?
I am using AX 2012 Feature Pack
You cannot close financial period Period 7 because it is referenced by open transactions. You must post, delete, or change the transaction date of the open transactions before you can close the financial period.
Cheers
dear suzyan
please open new job and type this code and change the period name from fiscal calender period #
static void LKLGrootboekPeriodeAfsluitingWD(Args _args)
AccountingDistribution accountingDistribution;
FiscalCalendar fiscalCalendar;
FiscalCalendarPeriod fiscalCalendarPeriod;
FiscalCalendarPeriod _currentPeriod;
Ledger ledger;
counter teller =0;
counter tellervoor =0;
counter tellerna=0;
while select accountingDistribution
tellervoor++;
select * from _currentPeriod where _currentPeriod.RecId==5637147130; //Replace RecID by FiscalCalendarPeriod recID of affected period
if (_currentPeriod)
ttsBegin;
while select forUpdate RecId from accountingDistribution
where accountingDistribution.AccountingDate >= _currentPeriod.StartDate &&
accountingDistribution.AccountingDate <= _currentPeriod.EndDate &&
accountingDistribution.AccountingEvent == 0
exists join ledger
where ledger.PrimaryForLegalEntity == accountingDistribution.AccountingLegalEntity
exists join fiscalCalendar
where fiscalCalendar.RecId == ledger.FiscalCalendar
exists join fiscalCalendarPeriod
where fiscalCalendarPeriod.FiscalCalendar == fiscalCalendar.RecId &&
fiscalCalendarPeriod.RecId == _currentPeriod.RecId
//nable the row below to automatically delete the record
AccountingDistribution.doDelete();
teller++;
ttscommit;
tellerna++;
info(strFmt(“Amount of records before the problem record(s) were deleted from table Accountingdistribution: %1”,tellervoor));
info(strFmt(“Deleted: %1”,teller));
info(strFmt(“Amount of records after the problem record(s) were deleted in table Accountingdistribution: %1”,tellerna));
if(tellervoor-teller==tellerna)
info(“Check: OK!”);
else
info(strFmt(“Check: Error! Before %1 - deleted %2 is not %3 (result after deletion)”,tellervoor,teller,tellerna));
