I want to insert the username or userid into table
i used this code to find the username of the system
curuserid();
this is not working…i want to find the username or userid of the system using coding of X++
curuserid();
Hi Manimaranvasan,
Try this code in Job
print xUserInfo::find().id;
print xUserInfo::find().name;
pause;
Hi Manimaranvasan,
It will work. I don’t how r u using that method. Better try the below code in job and apply it to your object if it works fine.
str s;
s = curUserId();
info(strFmt("%1", s));
Try this in job. Hope it works.
If you want the name of the userid, try the below code in job.
str s;
s = xUserInfo::find().name;
