In the form i have option global variable with option minimum,maximum,Average and a textbox to dispaly a result.
Based on the option it should calculate the min,max,mean of the RESULT field and display it in the textbox…
Please help…
Please help…
Hi Bavani,
what have you tried so ve you tried so far? Are you getting some error message?
Hi David,
In the OnValidate trigger of the option textbox i wrote the following code
IF View = View::Minimum THEN
SETFILTER(Result,’%1’,Result);
“Row Result”:=GETRANGEMIN(Result);
IF View = View::Maximum THEN
“Row Result”:=GETRANGEMAX(Result);
But its showing me the error:
Please specify a filter for the result field in the Table.
In the OnValidate trigger of the option textbox you wrote the following code
SETFILTER(“Result”,MinValue…MaxValue);
Just try it
Im getting the same error
I tried the following code but im not getting the output
BEGIN
glbrecrules.RESET;
IF glbrecrules.FIND(’-’) THEN BEGIN
“Row Result” := glbrecrules.Result;
REPEAT
IF “Row Result” > glbrecrules.Result THEN
“Row Result” :=glbrecrules.Result;
UNTIL glbrecrules.NEXT = 0;
END;
// “Row Result” := glbrecrules.Result;
END;
