How to filter the Temparory table , in forms , In this scenario getting the data for filtering
How to filter the Temparory table , in forms , In this scenario getting the data for filtering in Regular Table How To Get
Can you please elaborate? Please provide enough description of the issue.
In My case I need to filter the values in Transactions , when I open this form the values are no need to show , that’s why iam using temporary table , if I set to give the range in filter that values only show
You don’t want the values of particular fields to be seen or you want to filter the records. I am still not clear.
Is that a standard form?
Thanks For Reply, I need to filter the Regular Table , But If I use the datasource for Regular ,For the First Time No Need To Show The Data , If I set to Range that will filter , That is why iam using TmpDB Table , Is It available in standard
Sridar can you please tell me for what purpose you are using temporary table?
I need to show the data empty in the grid while open the form so for that am using temp table and I need to filer the data based on the account num and vendgroup the data shoul be shown in grid
when you open your form ,grid should be empty and when you apply filter for certain fields grid should display the exact records corresponding to the filter value?
just tell me whether this is the exact scenario?
Yes
See if above is the case, then just disable the datasource of the table in datasource init method of the form and enable it when you perform filter operation. Don’t use the temporary table.
Form → datasource → yourtable → override init method
use the below code
this.query().datasourceno(1).enabled(false);
So that it wont’t show any records when you open up the form.
