I hv problem. I have a lookup field.
In my lookup field appears : CR-001, RM-001, RV-002, etc
I want to filter it so the only field appears is RM-001.
What should i write?
Regards
Regards
Override lookup method of the field in form datasource as below
public void lookup(FormControl _formControl, str _filterStr)
SysTableLookup sysTableLookup;
Query query;
QueryBuildDataSource queryBuildDataSource;
//Comment super
//super(_formControl, _filterStr);
sysTableLookup = SysTableLookup::newParameters(tablenum(TableName),_formControl);
//below are the list of fields which show in lookup
sysTableLookup.addLookupfield(fieldnum(TableName, FieldName1),true);
sysTableLookup.addLookupfield(fieldnum(TableName, FieldName2),false);
sysTableLookup.addLookupfield(fieldnum(TableName, FieldName3),false);
query = new Query();
queryBuildDataSource = query.addDataSource(tablenum(TableName));
//For sorting the order by selected field
queryBuildDataSource.addSortField(fieldNum(TableName,FieldName),SortOrder::Ascending);
//For filtering the record by specific value
queryBuildDataSource.addRange(fieldnum(TableName,FieldName)).value(queryValue(“RM-001”));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
yes…i am writting
queryBuildDataSource.addRange(fieldnum(TableName,FieldName)).value(queryValue(“RM*”));
to return all the fieldName with the code RM
but it return nothing…i dont know what’s going wrong…
You should try the following : queryBuildblablabla.value(“RM*”) instead of queryBuildblablabla.value(queryValue(“RM*”));
regards,
Thomas
it works man…
thx bro
