How to filter records in form
I am new to AX.I need when i open the form it filters the
records & show me the records of today only(nt the records inserted before date).
In init how to write.
Thanks in ADV.
hi Sambit Mohapatra
  1. the field that u want to filter must be change Properties AutoDeclaration to True
  2. use this code in FirstField Method or Other Method : FieldName.filter(Today( ))
Take a look at smmTransLog Form for inspiration. (which has from date and to date, use single date in your case)
Please check with below code on init.
QueryBuildDataSource qbds;
QueryBuildRange CreatedDaterange;
super();
qbds = this.query().dataSourceTable(tableNum(“table_name”));
CreatedDaterange = qbds.addRange(fieldNum((table_name",CreatedDateTime));
CreatedDaterange.value(queryValue(today()));
