I’ve a filter fromdate and todate in my form, based on the date the form need to show the records.
I tried using executequery in datasource like this:
public void executeQuery()
QueryBuildRange QcustomerFilter;
QueryBuildRange ShippingDateConfirmedFileter;
QcustomerFilter = SysQuery::findOrCreateRange(CustPackingSlipJour_q.datasourceTable(tableNum(CustPackingSlipJour)),fieldNum(CustPackingSlipJour,SalesId));
ShippingDateConfirmedFileter = SysQuery::findOrCreateRange(CustPackingSlipJour_q.datasourceTable(tableNum(SalesLine)),fieldNum(SalesLine,ShippingDateConfirmed));
if (FromDate.dateValue()!=utcDateTimeNull() && ToDate!=utcDateTimeNull())
ShippingDateConfirmedFileter.value(SysQuery::range(fromdate.dateValue(),todate.dateValue()));
else
ShippingDateConfirmedFileter.value(SysQuery::valueUnlimited());
//ShippingDateConfirmed
super();
I’ve error on this line and also I want to know whether it will work or not?
Thanks.
kranthi
January 18, 2018, 12:29pm
2
It is not dateTime field, it only date.
So you should be using dateNull()
Yes, Kranthi.
But I want my form to be empty when I open, once i gave the date it should display the records based on the filter.
How could I do that?
In the init method, try to add a range on any field that will not be empty by using sysQuery::valueEmptyString());
(Example - salesId), so that form will open empty. Clear the range after specifying the dates.
public void init()
DeliverydateFilter = sysQuery::valueEmptyString(CustPackingSlipJour_q.datasourceTable(tableNum(CustPackingSlipJour)),fieldNum(CustPackingSlipJour,SalesId));
super();
Is it right?
The error is telling you that you’re calling a method with a wrong number of parameters. And indeed, you’re trying to call valueEmptyString() with a parameter, but it doesn’t except any. You probably meant something like addRange(…).value(SysQuery::valueEmptyString()) .
CustPackingSlipJour_q.datasourceTable(tableNum(CustPackingSlipJour)).addRange(fieldNum(CustPackingSlipJour,SalesId)).value(SysQuery::valueEmptyString());
Sorry I didn’t understood, could you explain me more clear?
