I’ve a itemid filter in my form based on this itemid I’m inserting records in temptable…
Here my code is
public void executeQuery()
str 50 getitemid,getitem;
getitem=StringEdit.text();
select bmv where bmv.ItemId == getitem && bmv.Active == NoYes::Yes;
if (bmv.RecId)
getitemid= bmv.ItemId;
while select bmlines join prodtable join trans join invent where bmlines.BOMId == bmv.BOMId
&& trans.ItemId==invent.ItemId && prodtable.InventRefId==trans.SalesId
&& (trans.ItemId==prodtable.ItemId && prodTable.BOMId==bmlines.BOMId
&& trans.DeliveryDate>=FromDate.dateValue()
&& trans.DeliveryDate<= ToDate.dateValue())
tmpprodtable.ItemId = bmlines.ItemId;
tmpprodtable.ParentId = getitemid;// "GM-961-006";
tmpprodTable.ProdId = prodtable.ProdId;
tmpprodtable.SalesId = trans.SalesId;
tmpprodtable.Name =bmlines.itemNameGrid();
tmpprodTable.BOMConsump = prodjournalbom.BOMConsump;
tmpprodtable.InventLocationId = inventdim.InventLocationId;
tmpprodtable.DeliveryDate = trans.DeliveryDate;
tmpprodtable.PackingSlipId = trans.PackingSlipId;
tmpprodtable.Revision = inventdim.InventColorId;
tmpprodtable.InventTransId = prodbom.InventTransId;
tmpprodtable.BOMQty = prodbom.BOMQty;
//tmpprodtable.
tmpprodtable.BOMId = bomTable.BOMId;
tmpprodtable.QtySched = prodtable.QtySched;
tmpprodtable.QtyBOMCalc = prodbom.BOMQty * prodtable.QtySched;
tmpprodtable.Variance = tmpprodtable.QtyBOMCalc - tmpprodtable.BOMConsump;
tmpprodtable.fDate = trans.DeliveryDate;
tmpprodtable.tDate = trans.DeliveryDate;
// tmpprodtable.Name = InventTable::find(bmlines.ItemId).ItemName;
tmpprodtable.UnitId = prodbom.UnitId;
tmpprodTable.insert();
if (bmlines.BOMQtySerie==0)
tmpprodtable.TotalOrdQty = _totalOrdQty * (bmlines.BOMQty / 1);
tmpprodtable.RequiredQty = _salesQty * (bmlines.BOMQty / 1);
else
tmpprodtable.TotalOrdQty = _totalOrdQty * (bmlines.BOMQty / bmlines.BOMQtySerie);
tmpprodtable.RequiredQty = _salesQty * (bmlines.BOMQty / bmlines.BOMQtySerie);
info(strfmt("%1|%2|%3|%4 %5 %6",tmpprodtable.ItemId,trans.SalesId,bmlines.itemNameGrid(),tmpprodtable.ParentId,tmpprodTable.ProdId,tmpprodTable.Variance));
super();
when i debug the code its not going through the loop, how can I pas the itemid from filter to my select statement.
