Hi Friends,
Here is the requirement, From form using ctrl+F3 user can save the query in syslastvalue [Lets say Qry:64_64V]. When I open the form next time I need to show all the saved query in a combobox in the form. When user selects any of the saved query the form should execute according to it.
I managed to get the user saved query name from the sysLastValue, but I am not able to get the query from it.
Select SysLastValue
Where SysLastValue.userId == curUserId()
&& SysLastValue.company == curext()
&& SysLastValue.recordType == UtilElementType::UserSetupQuery
&& SysLastValue.designName == #OrderManagementview;
SavedQueries.add(’’); // Add Blank to the comboBox
if(SysLastValue)
//if SysLastValue has record get the value fron sysLastValue table into container
savedqryContainer = SysLastValue.value;
//Loop through the container and find the name of the saved query
for(i = 3; i<= conlen(savedqryContainer);i++)
if (conPeek(conPeek(savedqryContainer,i),1) != #lastUsed)
name = conPeek(conPeek(savedqryContainer,i),1);
SavedQueries.add(name);
Can any one help tp get the query saved for each name.
