How to exclude GL with zero balance print in Trial Balance Axapta report
Dear all expert,
Is that any function or solution to exclude GL with zero balance print in Axapta Trial balance standard report?
Eric
hi,
The standard report can be viewed in two levels
one is details level means it will print with the transactions
other one is summary means it prints the balances…
which level you are using
if you are using the summary level the requirement cannot be achieved directly it needs to customized…
hope it will help you
Regards
Kranthi
