How to enable Workflow Properties Extension Form Design Node
Hello All, I am working on a workflow on Inventory movement Journal via extension. Who can tell me how to successfully enable the workflow properties on my form.
When I try do that directly using the property window and compile.
[ExtensionOf(formStr(InventJournalMovement))]
final class InventJournalMovementForm_Extension
[FormDataSourceEventHandler(formDataSourceStr(InventJournalMovement, InventJournalTable), FormDataSourceEventType::Initialized)]
public static void InventJournalTable_OnInitialized(FormDataSource sender, FormDataSourceEventArgs e)
InventJournalTable inventJournalTable;
sender.formRun().design().workflowDatasource(inventJournalTable);
sender.formRun().design().workflowEnabled(true);
sender.formRun().design().workflowType(“InvMovJourWFType”);
This class seems to compile without error. And when I launch the form. it throws an error: Menu item could not be opened.
Kindly provide help.
Warm Regards
