How to enable or disable menuitem button based on the enum field in ax 2012
Hi ,
I have one requirement in ax 2012…
When we will open the sales and marketing >>all quotations >>quotation
In this form I have one filed called quotation stage (enum type :: Sample and PPAP ) based on the this field I want enable or disable menuitem button on custquotationtrans form …
Already I created 2 menuitem button type display.1.sample card
2.PPAP card information
If we I select the " sample" at quotation stage PPAP card information menuitem should disable …
If we select the PPAP at quotation stage sample card should be disable even enable also no problem …
I added this menuitem buttons at line level not header level …
Ok, so you have added a field to SalesQuotationTableListPage. In which table you have added that field?
Is that a custom form?
You can write your code disable/enable in a method and call then method when the stage is modified and in the active method of the form data source.
we added field at SalesQuotationTableListPage and table SalesQuotationTable …
Have you tried the below?
You can write your code disable/enable in a method and call that method when the stage is modified and in the active method of the form data source.
