how to email PO in AX 2012
when a user create a PO, how could I set up AX so that it can email a copy to the user who created it in AX 2012
Hi patrick Am…
this is the code to send the mail through x++…
static void c_SendQuickMail(Args _args)
//str ToAddress = “chaitanya.k@dhanushinfotech.net”;
str FromAddress = “chaitanya.k@dhanushinfotech.net”;
str Subject = “New2”;
str Body = “Hi”;
str FileToAttach = “D:\fn.pdf”;
SysMailer mailer = new SysMailer();
mailer.ccs().appendAddress(“chaitanya.k@dhanushinfotech.net;ramakrishna.k@dhanushinfotech.com”);
mailer.quickSend(fromaddress,"chaitanya.k@dhanushinfotech.net",subject,body,"",FileToAttach);
write the above code in purchtable insert() method… using the created by field…
So u can set an automatic mail… to the user who creates the PO…
