Im trying to edit the standard filed on the PurchTable form using active method
[ExtensionOf(FormDataSourceStr(PurchTable,PurchLine))]
final class PurchTable_Form_Extension
public int active()
int ret = next active();
PurchLine purchLine = this.cursor();
PurchTable purchTable = this.cursor();
if(purchTable.PurchStatus == PurchStatus::Backorder)
this.formRun().design().controlName(‘PurchLine_ItemName’).allowEdit(true);
this.formRun().design().controlName(‘buttonUpdateReceiptsList’).enabled(false);
else
return ret;
my code is running fine for customize field but it did’nt work for standard field
im trying to edit the product name here using its controller name but this above code is not working for the standard field
