How to edit or freeze only selected record on a grid through Edit/Freeze button on form.
I have created a form called ‘abc_budget’ and data source associated with this form is ‘abc_budget’ table which is containing following three fields :
(a) Date
(b) Amount
(c) Freezed (checkbox)
I took a grid on the form having these 3 fields and two buttons (Edit & Freeze) to edit or freeze the particular selected record.
As if we freeze any record , the ‘Freezed’ checkbox associated with that record should be automatically checked, and if we make any record editable by clicking on ‘Edit’ button ,the ‘Freezed’ checkbox should be automatically unchecked.
I have attached screen shot of the form.
Issue resolved.
Step 1 :
On Data source, write ‘Active’ method as below :
public int active()
int ret;
ret = super();
if(abc_budget.Isfreezed == noyes::Yes)
abc_budget_DS.allowEdit(false);
Freeze.enabled(false);
Edit.enabled(true);
else
abc_budget_DS.allowEdit(true);
Freeze.enabled(true);
Edita.enabled(true);
return ret;
Step 2 :
On ‘Edit’ Button , write clicked method as below :
void clicked()
super();
if(Box::yesNo(“Are you sure you want to edit the selected record ?”,DialogButton::Yes) == DialogButton::Yes)
abc_budget.Isfreezed = NoYes::No;
abc_budget.write();
abc_budget_DS.allowEdit(True);
abc_budget_DS.reread();
Step 3 :
On ‘Freeze’ Button , write clicked method as below :
void clicked()
super();
if(abc_budget.Isfreezed == NoYes::Yes)
info(“Selected record is already freezed.”);
else
if(Box::yesNo(“Are you sure you want to Freeze selected record ?”,DialogButton::Yes) == DialogButton::Yes)
abc_budget.Isfreezed = NoYes::Yes;
abc_budget.write();
abc_budget_DS.allowEdit(False);
info(“Selected record is now freezed.”);
Now form will work properly.
Regard,
Deepankar Sharma
