I would like to create a copy of one of the existing SSRS reports in AX 2012 to use as basis for a customized report.
The reason is that I want to leave the original report untouched.
How can I achieve this?
1- Open VS
2 - go into the application Explorer
3- choose the report you want duplicate
4- duplicate the report
5- for to each data set parameter change the name of the report to match the new name
Ok. But exactly, how do you duplicate it? Really can’t find the a way to do it :S
Thanks for your reply!
Regarding “5- for to each data set parameter change the name of the report to match the new name”,
I am not able to find the report name in the data set parameters. Can you explain exactly what field you are referring to?
This is my own solution to duplicate SSRS report with no error http://axvuongbao.blogspot.com/2013/08/how-to-duplicate-ssrs-report-in-ax2012.html
