How to divide the Duration data type by 2
how to divide the 21 hours 55 minutes 50 seconds(Duration Data type) by 2 in NAV 2013 Reports
please help me
Just like any other fields: NewDuration := Duration / 2;
Thanks Erik
by 2 its working fine but if i use by 3 it is not working it gives error
AvgTotalResTime:=TotalResTime/3; in NAV 2013 Report
Microsoft Dynamics NAV
Overflow under conversion of Microsoft.Dynamics.Nav.Runtime.Decimal18 value 52436666.6666666667 to System.Int64.
OK
[deleted]
Actually better like this:
AvgTotalResTime:=ROUND(TotalResTime/3,1);
Thanks Erik
Its working fine
Hi SubbaReddy
The error you have mentioned
“Overflow under conversion of Microsoft.Dynamics.Nav.Runtime.Decimal18 value 52436666.6666666667 to System.Int64.”
I am receiving the same error.
I am not a developer but, I was wondering if you can please guide me through. Where I can put this formula “AvgTotalResTime:=TotalResTime/2” or as Erik suggested to use “AvgTotalResTime:=ROUND(TotalResTime/3)”
Cheers
Syed
Hi Syed,
Well unless you need to divide the duration, then you should not use this formula.
The error you are getting is a quite normal programming error. So it may not even have anything to do with duration fields.
And please if it’s not related to duration/development, then ask this as a new question instead, then I’m sure somebody can help you. [:)]
