i want to show vendor address and contact details on PO Print
the vendor name only is showing
please help urgently
Hi Ahmed,
If the printed fields are available in the datasource, you can add them to your design. Else i would suggest to use display method on the table.
Jurre
thanks jurre
i could do this by adding the desired data into the address tab in vendor details form
but you suggested to use display method on the table
well the table is VendPurchOrderJour how can i use this display method on the table
and what does this means???
In the respective table, write a display method like,
display Addressing vendorAddress
return VendTable::find(this.orderaccount).address;
just paste the same code in ur table new method… then create a string field in ur report and associate the data method with this display method nAME
thats it
