Hello Friends,
In Purchtable Form - When we select new PO then how to display the vendor name and vendor details on form.
and in line when we select new item then hoe to display unit Price and quantity of item.
Please help me…
Hello Friends,
Please help me…
Is it related to NAV or AX?
Hello Friends,
and in line when we select new item then hoe to display unit Price and quantity of item in Dynamics AX 2009
If i m understood your problem correctly then you want vendor name n other details at your purchase order form ??
For that you have to use the vendor account number or you have to join the vendor details table with PurchTable n link the vendor account field of both table
after that you can simply drag and drop the field in the grid of that form and you can get the appropriate result…
same logic will be apply in line also…
it works for sure…
regards,
Viral
