How I set condition that show an error message if I select “Start Date” less than the previous “End Date” in Sales Price (ID: 7002) Table.The Start Date must be greater than the previous End Date.
For this I try to write a code in the on Validate trigger of Start Date in sales price table (ID: 7002).But It’s not working properly.
My following code is:
SalesPrice.SETRANGE(SalesPrice.“Item No.”,“Item No.”); //“Here I assign SalesPrice as a Record variable”
SalesPrice.SETRANGE(SalesPrice.“Sales Code”,“Sales Code”);
IF SalesPrice.FINDLAST THEN BEGIN
IF SalesPrice.“Starting Date”<“Ending Date” THEN
ERROR(‘StartDate Must Be Greater Then Previous EndDate’);
END;
Kindly check and give a sugg.
Thank you.
