Hello friends,
Has anyone overcome this kind of situation wherein a financial dimension has to be disabled based on another financial dimension.
Ex: Whenever CostCenter is changed, Department should be disabled.
Please provide your views.
Amar
Hi Amar,
Did you get a solution of the above problem?
Regards
Anuj
Hi Aman,
What do you mean by Disable, is it deleting the Financial Dimensions ???
If Yes, then there are some pre-requisites to be looked into.
there should’nt be any transaction related with that Financial Dimension
If there is any advance rule structure attached to the financial Dimension, firstly you have to delete it and then delete the dimensions.
There is another way by making the Dimensions not mandatory, this can be done by selecting the Dimension onto the dimension name we get to see a filter, select it and a form opens and to the bottom of the form you find an option call Allow blanks. This can be used as a reference if required.
… if this post is informative and helpful, please verify the Solution… wuld be thankful …
TQ
[Y]
Hi Anuj and Ashwin,
It is not deleting the financial dimension. When one financial dimension is changed the other dimension should be uneditable.
Amar
